Retired_Member
Aug 17, 2011Seagate Barracuda ST32000542AS
I have 4 of them in my NVX and I need to replace one but apparently Seagate substituted it with the ST2000DL003.
Anyone can tell me if it will work with my NVX and the tree older drives ?
Thank you.
Thank you.
1 Reply
- PapaBear1ApprenticeUnfortunately, the ReadyNAS forum is in the process of copying files over to a new server and the Hardware Compatibility List (HCL). I was going to look up whether the Samsung HD204UI is on the HCL for the NVX. It does have a higher rating than the Seagate ST2000DL003. Some members have had problems with them in the early days. Of course some of the problems may result from poor packing and handling of OEM drives.
