JarleH
Apr 14, 2010Aspirant
Clicking sound with Seagate Barracuda LP ST32000542AS 2TB
Hi I got a new NVX and at that moment these Seagate disks were the only ones on the compatibility list, so I was stupid enough to buy 4 of them. (Shame on you Netgear for not having more disks on t...
mdgm-ntgr
May 12, 2010NETGEAR Employee Retired
It appears that a lot of the 2TB disks have their drawbacks. You should do thorough research and then make a decision. Having said that my personal preference is not to use WD Green disks due to the possible compatibility issues.
- Aug 17, 2011Retired_Member
