JarleH
Apr 14, 2010Aspirant
Clicking sound with Seagate Barracuda LP ST32000542AS 2TB
Hi I got a new NVX and at that moment these Seagate disks were the only ones on the compatibility list, so I was stupid enough to buy 4 of them. (Shame on you Netgear for not having more disks on t...
maxblack
May 12, 2010Aspirant
Presumably you are referring to the last bullet item:
mdgm wrote: One thing you could try is the long S.M.A.R.T. tests. See http://home.bott.ca/webserver/?p=252. While not as good as removing the disks and checking them, this is still better than the short S.M.A.R.T. tests.
# Test Disks (new option as of 4.2.9)
which was not described in the article at all. Does it go without saying that this is a non-destructive test? :scared:
- Aug 17, 2011Retired_Member
