JarleH
Apr 14, 2010Aspirant
Clicking sound with Seagate Barracuda LP ST32000542AS 2TB
Hi I got a new NVX and at that moment these Seagate disks were the only ones on the compatibility list, so I was stupid enough to buy 4 of them. (Shame on you Netgear for not having more disks on t...
PapaBear1
Oct 01, 2010Apprentice
Well, PedroRio has a Duo which cannot run the x86 based 4.2.13, the current official sparc version is 4.1.6 with 4.1.7 T9 beta available although betas are generally not good to use for operational use (that's why they are in beta test to determine if they are stable).
PedroRio you did not post the firmware version of the ST32000542AS drives. This info is available on the drive label (original fw only) and also in the smart information accessible in Frontview by clicking on status and then health. It will show the two drives, their temp and other stats and when you click on the Smart info button, the firmware is displayed. If the firmware is less than CC35 it should be upgraded to CC35. Here is the Seagate link:
http://seagate.custkb.com/seagate/crm/s ... cId=213915
- Aug 17, 2011Retired_Member
