JarleH
Apr 14, 2010Aspirant
Clicking sound with Seagate Barracuda LP ST32000542AS 2TB
Hi I got a new NVX and at that moment these Seagate disks were the only ones on the compatibility list, so I was stupid enough to buy 4 of them. (Shame on you Netgear for not having more disks on t...
PapaBear1
Oct 02, 2010Apprentice
You will have to turn off the Duo, install/connect each drive to a PC with SATA connections to do the upgrade. If you do not have a spare SATA cable, you can temporarily disconnect the DVD drive and use it's SATA and power connectors.
Be sure to back up you critical/important data first, of course the best scenario is a complete and current backup before you do the upgrade. Murphy is lurking.
- Aug 17, 2011Retired_Member
