JarleH
Apr 14, 2010Aspirant
Clicking sound with Seagate Barracuda LP ST32000542AS 2TB
Hi I got a new NVX and at that moment these Seagate disks were the only ones on the compatibility list, so I was stupid enough to buy 4 of them. (Shame on you Netgear for not having more disks on t...
PapaBear1
Oct 16, 2010Apprentice
You can try a connection via USB, but it would be better if you simply took the side panel off your desktop, set the HD on a padded surface to protect the electronics and used the SATA cables from the DVD drive. Try the USB and see what happens. The worst case, the application to update the FW on the HD will not recognize the presence of the drive connected to the USB channel.
The reason I asked, is that some members in today's market have only laptops.
- Aug 17, 2011Retired_Member
