JarleH
Apr 14, 2010Aspirant
Clicking sound with Seagate Barracuda LP ST32000542AS 2TB
Hi I got a new NVX and at that moment these Seagate disks were the only ones on the compatibility list, so I was stupid enough to buy 4 of them. (Shame on you Netgear for not having more disks on t...
XBower
Oct 21, 2010Aspirant
Hi.
I logged a case with Seagate support about this.
Not one our later (really fast) I got this answer:
"Thank you for the information. We check your drives and there was no firmware update available for them. They have been already updated from the original version. The reason why it's still showing CC34 is because it was the original version and an update was performed on the field not in the factory."
But the clicking sound still continues, and I can't really tell witch drive makes it.
Regards
Regards
- Aug 17, 2011Retired_Member
