Maxpower411
Mar 12, 2021Aspirant
Command Timeouts The Chcken or The Egg ReadyNas 516 12TB IronWolf Pros
System Disk 1 has 1 Command Timeouts Disk 2 has 3 Command Timeouts Logs 2021-02-23 16:11:08: raidard[18963]: segfault at 7ffda792b000 ip 0000000000401d20 sp 00007ffda79278d8 error 4 in raidard[...
- Mar 25, 2021
Stephen- Thanks Again for all, your help- Things look great here. One Disk replaced completely and resynced, the second at 85% resynced. No Errors, No timeouts.
It took 3 days, 14 hours, 5 minutes to resync the first drive, probably the same for the 2nd.
When you are dealing with 12TB drives....wait!!
I will close this topic, offer thanks and kuddos.
Jeff
Maxpower411
How do a run a disk test from the Volume menu? I am clueless on this .All I have seen is the ability to hover over each disk and look at it.
I did not get a critical error. The error I showed came up from diagnostics in Raidr. It also showed in the disk area of my downloaded files.
If I was to check the drive with a PC, the procedure whould be shut down the nas. Pull the Drive. Put it on my USB dock. Then Run a seatools program. Which Program? I am hoping I do not have to do this, and wondering if the log files can help diagnose this. Will the seatools progam address the command timeouts, and truly consider the disk bad, not all timeouts are critical- OR NOT.
Thanks for the info
Jeff
Maxpower411
Disk 2 Was the last disk to resync. (This just dawned on me)
I never saw a way to test Disks in the Volume Area
