mjlarrabee's avatar
mjlarrabee
Follower
Jan 22, 2018
Compatibility Lists?!?!?!
OK, so I understand that it's and older model, and that "any 2tb drive on the compatability list" will work - But the compatability list for the RND4000  is simply NOWHERE TO BE FOUND.  30 Minutes of searching is (rather, should be) more than enough to find a list of compatible drives for a product.
Can anyone direct me to the ACTUAL list of drives compatible with the RND4000 v1?  Please don't suggest a particular drive, please don't re-link me to the compatability list selection page (the drive model isn't there.  for whatever reason..), just a link to drives that the RND4000  will support should be fine.  Thanks!
1 Reply
ProSupport for Business
