JustKJ
Jan 23, 2013Aspirant
Compatibility Question
I was looking at the USB compatibility post and it has not been updated in a while. I am looking for a Portable USB drive to backup my ReadyNAS NV+ and then store offsite. Current I have 4 1TB driv...
Jan 23, 2013Guru - Experienced User
If you have an NV+ V1 (likely given your forum join date), then you can only connect 2 TB drives directly to the NAS.
You can back it up over the network to a USB drive attached to your PC. If your network is gigabit, then that would be faster, though of course you need both devices running.
