matt_kaye
Apr 11, 2016Aspirant
Confused. trying to set up my readynas.. had it up and running a few years ago but stopped using it
Help I have a readynas duo2 I have managed to install raidar which finds the drive on the network and displays everything as healthy including the drive. However I am unable to find the d...
BrianL2
Apr 11, 2016NETGEAR Employee Retired
Hi matt_kaye,
Welcome to the community!
Is there an error message when you tried to access it via File Explorer? On the RAIDar window, did you notice if the IP address is different from the IP subnet where your PC is connected? Lastly, is the admin page accessible?
Kind regards,
BrianL
NETGEAR Community Team
matt_kaye
Apr 12, 2016Aspirant
on raidar version 6.1 it displays
Model: ReadyNAS Duo
Status: Healthy
Firmware: 4.1.8
IP Address: 192.168.0.36 (00:24:B2:0A:17:9A)
Thanks for any further help
- matt_kayeApr 12, 2016Aspirant
It did initially display an error message. if skipped it loads frontview up ok
The error message is:
An unexpected error is keeping you from copying the file. if you continue
to receive this error, you can use the error code to search for help with this
problem.
Error 0x800004002 No such interface supported
ReadyNAS Frontview
Try again Skip
- BrianL2Apr 12, 2016NETGEAR Employee Retired
Hi matt_kaye,
Could you confirm the IP address of your PC? Do you have a spare or fresh drive that you can use? Also, post some screenshots like its status on the RAIDar utility and the page when the admin (Frontview) is being accessed.Kind regards,
BrianL
