chuckk9033
Jun 27, 2020Aspirant
Confusion About Syncing ReadyNAS with Amazon S3 Pre-existing data
Replacing an older ReadyNAS with the 2304. The new NAS is populated with the files from the old NAS and those files are also already in Amazon S3. If I connect the new NAS mapped to the correct buc...
- Jul 05, 2020
Well, it seemed to work except all the file dates changed to the current date vs. the real date of the file. Anyway, it's all fine. Thanks.
Marc_V
Jul 02, 2020NETGEAR Employee Retired
Welcome to the Community!
Since they are on the same drive and nothing has changed but the chassis and also the same settings and aithentications are correct, there is a chance duplication of files will not occur. If ever, it is also possible that it will be synced with a different name.
HTH
