Jacobnz
Jun 18, 2019Guide
Connected, no internet
I'm a rookie and I know nothing about networks etc. So please talk in noobie terms. I have connected my nas to the back of the wireless router via ethernet cable, I can log in to the admin page and...
- Jun 18, 2019Solved.
When looking at the screenshot I noticed the date on the nas was set to 2016.
Once setting that to the correct date all issues resolved.
Marc_V
Jun 18, 2019NETGEAR Employee Retired
Have you checked if you have Internet connection from your router and that other devices can connect to on the Internet? Is the ReadyNAS joined already on ReadyCloud? You have access over LAN so you just need to make sure that the router can connect on the Internet.
Try to reboot both NAS and router or if you have set a static IP on the NAS then change it back to DHCP. Hope to hear an update.
HTH
Regards
- StephenBJun 18, 2019Guru - Experienced User
Also, is it possible that your router is set up to block internet access for devices unless you explicitly tell it to allow it?
What router do you have (manufacture + model)?
What router do you have (manufacturer + model)?
- JacobnzJun 18, 2019GuideI have internet working off every other connected device in the house, just the readynas can't check for updates and although the readycloud app is set to on it shows as device offline when I try and access via the android ready share app.
All was working at my old address.
I've looked at the router and it looks as though it sees the nas as connected. The router is a spark modem HG659b.
Screen shot attached from trying to check firmware via the admin page.
- JacobnzJun 18, 2019GuideSolved.
Once setting that to the correct date all issues resolved.- StephenBJun 19, 2019Guru - Experienced User
Jacobnz wrote:
When looking at the screenshot I noticed the date on the nas was set to 2016.By default the NAS uses NTP to get current time over the internet. Did you change that setting when you set it up?
- JacobnzJun 19, 2019GuideNo, I have never even noticed those details. It could be from the os re install I did a few days ago in an attempt to get router access.
