Jacobnz
Jun 18, 2019Guide
Connected, no internet
I'm a rookie and I know nothing about networks etc. So please talk in noobie terms. I have connected my nas to the back of the wireless router via ethernet cable, I can log in to the admin page and...
- Jun 18, 2019Solved.
When looking at the screenshot I noticed the date on the nas was set to 2016.
Once setting that to the correct date all issues resolved.
Jacobnz
Jun 18, 2019Guide
Solved.
Jun 19, 2019Guru - Experienced User
By default the NAS uses NTP to get current time over the internet. Did you change that setting when you set it up?
- JacobnzJun 19, 2019GuideNo, I have never even noticed those details. It could be from the os re install I did a few days ago in an attempt to get router access.
- StephenBJun 20, 2019Guru - Experienced User
Jacobnz wrote:
No, I have never even noticed those details. It could be from the os re install I did a few days ago in an attempt to get router access.It shouldn't have changed that setting, but of course something odd might have happened.
Click on the settings wheel next to "device time" in the web ui (system->overview).
Confirm that the time zone is correctly set for your location, and also confirm that "synchronize clock with an internet server" is checked.
If you aren't syncing with an internet time server, the time will gradually drift (though not by three years :smileyfrustrated: )
