sowelu66
Oct 08, 2011Aspirant
Connecting mac book air with Lion to NAS NV+ directly
My NV+ was working fine through my router and an old macbook 2008 - now I got an air with lion and updated the firmware on the NAS as required and attempted a direct link from the NAS to the macbook a...
sowelu66
Thanks for your reply but I want to connect the NAS to my MacBook Air directly - using the ethernet cable plugged directly into the Mac (actually an ethernet USB adaptor as the Air does not have an ethernet port).
I want to go direct, bypassing the router - I understand it is possible.
The instructions sat to " .... first set a static IP address on your PC in the 192.168.168.xxx subnet, subnet mask 255.255.255.0. You can then use RAIDar to detect ReadyNAS, or you can open a browser and enter the ReadyNAS default IP address https://192.168.168.168/admin to connect to the ReadyNAS."
but I have no idea how to set up a static address on the Mac / NAS ? Anyone can help?
Thanks.
Thanks.
