sowelu66
Oct 08, 2011Aspirant
Connecting mac book air with Lion to NAS NV+ directly
My NV+ was working fine through my router and an old macbook 2008 - now I got an air with lion and updated the firmware on the NAS as required and attempted a direct link from the NAS to the macbook a...
sphardy1
Oct 08, 2011Apprentice
1. Your IP address should be of the form 192.168.168.xxx as described in the link given previously - so change it to 192.168.168.10 (instead of 192.168.1.10)
2. As you have not changed your NAS setup it should appear the same as when you used your previous MacBook, and you use it the same way.
3. The appearance of "homes"as a share means you are connecting to the NAS as the admin user instead of the whatever account you have setup on the NAS - so reconnect using the user credentials you were using when accessing the NAS from the older MacBook (probably called "relisuco")
