sowelu66
Oct 08, 2011Aspirant
Connecting mac book air with Lion to NAS NV+ directly
My NV+ was working fine through my router and an old macbook 2008 - now I got an air with lion and updated the firmware on the NAS as required and attempted a direct link from the NAS to the macbook a...
sphardy1
Oct 08, 2011Apprentice
sowelu66 wrote: I have set up my NAS in the "Share" security mode so there is only one "admin" account.
This contradicts your last post where you stated:
"homes" contains two shares "admin" and "relisuco"
If "homes" contains a folder called relisuco then there is a user with that name also defined which then suggests your NAS is not in Share security mode
If I type into safari;
https://192.168.168.10/admin/
It says page not loaded. it cannot find front view.
Because 192.168.168.10 is the address of your MacBook, not the NAS (which has address 192.168.168.168)
1) why is the Relisuco share empty (it has 180 GB of data)
2) I cannot find the "Storage" share - it does not show up in HomeHKNAS(AFP)
I would strongly recommend you contact Netgear Tech Support. If you have not changed your NAS setup then it should work as it did when connected via the router. Therefore you need someone to take a look at your NAS as the info you have provided is contradictory and anything I might suggest could result in data loss.
