mnrcotton
Jul 25, 2011Aspirant
Considering upgrade to ReadyNas Pro 6 from NVX using RaidX2
Hi - need to upgrade to a Pro 6 from a NVX with 4 Seagate 2TB ES drives in RaidX2 - will I be able to just put the 4 drives in the first 4 bays and carry on, adding other drives to expand the volume ...
mnrcotton
Jul 26, 2011Aspirant
intirid log:- [2011/02/17 23:08:58] Factory default initiated due to new disks (no RAID, no partitions)!
[2011/02/17 23:14:21] Updated from RAIDiator to 4.2.15.
[2011/05/08 20:28:44] Updated from RAIDiator 4.2.15 to 4.2.17.
[2011/07/26 01:00:54] Updated from RAIDiator 4.2.17 to 4.2.18.
Partition Log:- ***** partition output for sdd *****
Disk /dev/sdd: 3907029168 sectors, 1.8 TiB
Logical sector size: 512 bytes
Disk identifier (GUID): 025A1962-6646-4059-AE69-7057FA445E72
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 3907029134
Partitions will be aligned on 8-sector boundaries
Total free space is 5108 sectors (2.5 MiB)
Number Start (sector) End (sector) Size Code Name
1 64 8388671 4.0 GiB FD00 Linux RAID
2 8388672 9437247 512.0 MiB FD00 Linux RAID
5 9437256 3907024064 1.8 TiB FD00 Linux RAID
Disk /dev/sdd: 243201 cylinders, 255 heads, 63 sectors/track
Units = cylinders of 8257536 bytes, blocks of 1024 bytes, counting from 0
Device Boot Start End #cyls #blocks Id System
/dev/sdd1 0+ 242251- 242252- 1953514583+ ee EFI GPT
/dev/sdd2 0 - 0 0 0 Empty
/dev/sdd3 0 - 0 0 0 Empty
/dev/sdd4 0 - 0 0 0 Empty
