isaac82
Sep 21, 2012Aspirant
Continual SMART warnings - ReadyNas Duo
I have a ReadyNAS Duo, and have had a problem for the last couple of weeks where each time the NAS boots (once a day before I get home from work) where it emails me a warning of a SMART failure on dis...
mdgm-ntgr
Sep 21, 2012NETGEAR Employee Retired
Do you have any USB disks connected to the NAS. If so it's likely the SMART errors are on the USB disk. I've seen some reports of this issue recently.
Edit: What did you mean by SMART failure? I think I may have misread what you said. Do you mean things like ATA errors and Reallocated sectors. If so, I did read what you said correctly. However if you meant the disk did not pass the smart self-assessment test then that's a different matter.
