whyshouldI's avatar
whyshouldI
Copy problems from PC to NAS
Hi,
Few weeks ago I set the NAS all seemed well
Today I tried to copy a file from PC folder to NAS folder using windows explorer.
I got an error saying I needed permissions to copy
I can copy from NAS to PC
I can delete files on the NAS from windows.
Only copy does not work.
I have not changed any permissions or settings.
Not sure if this is a windows thing or NAS thing
An help appreciated
Thanks
  • I tracked it down further
    I was able to perfrom file operations onthe main folder
    I was not able on any of the sub folders
    I reset permission - it seemed to fix the problem
    • JennC's avatar
      JennC
      NETGEAR Employee Retired
      Hello whyshouldI,
      Sorry for the delay and it seems this post did not receive a response from other community members.
      Thank you for posting and updating with what helped you resolve the issue. Please mark your post as a solution to close this topic so it can also be of help to other community members who may be facing the same trouble.
      Please feel free to post any suggestion, questions and comments. We appreciate your contribution to the community!
ProSupport for Business
