TT_DE's avatar
TT_DE
Luminary
Feb 15, 2020
Copying a USB stick with 30 GB data to the NAS doubles the data volume from 1,5 TB up to 4 TB
i copied data from a us stick of 30 gb onto the nas. the data volume doubled from the former 1.5 TB to almost 4 TB.
The USB stick was encrypted with mcafee.
Does anyone have any idea what the cause may be and how I could delete the incremental data ?
    Never seen this before.  The encryption of the drive shouldn't matter.
    Maybe delete some of the oldest snapshots and then run a balance from the volume settings wheel.
    The Firmware ist 6.10.2
    Snapshots are activated
  • StephenB's avatar
    • TT_DE's avatar
      TT_DE
      Luminary
      Thank you for your feedback & recommendation.
      Will try and report afterwords.
      • TT_DE's avatar
        TT_DE
        Luminary
        Just startet the rebalancing process and the occopied volume reduces step by step.
        I am wondering what caused the doubling of the used data capacity. At the end the issue has been solved.
        Thank you for your help and guidance.
        Best
ProSupport for Business
