BrianLidd
Sep 08, 2014Aspirant
Corrupt Root issue
I had an old ReadyNas Duo that stopped working. I purchased a ReadyNas Duo 2, hoping to use the old disks with it. I swapped in the old disks and powered up the Readynas Duo 2. Raidar finds the Duo 2 ...
mdgm-ntgr
Sep 08, 2014NETGEAR Employee Retired
What happened to your original Duo? Why do you think it's no longer working?
Do you remember if you were using X-RAID or Flex-RAID?
