BrianLidd
Sep 08, 2014Aspirant
Corrupt Root issue
I had an old ReadyNas Duo that stopped working. I purchased a ReadyNas Duo 2, hoping to use the old disks with it. I swapped in the old disks and powered up the Readynas Duo 2. Raidar finds the Duo 2 ...
mdgm-ntgr
Sep 08, 2014NETGEAR Employee Retired
Sent you a PM.
Please note that the Duo v2 uses a different RAID format to the Duo v1.
If your Duo v1 can be booted to tech support mode then it would be best to investigate the problem using that.
