BrianLidd
Sep 08, 2014Aspirant
Corrupt Root issue
I had an old ReadyNas Duo that stopped working. I purchased a ReadyNas Duo 2, hoping to use the old disks with it. I swapped in the old disks and powered up the Readynas Duo 2. Raidar finds the Duo 2 ...
mdgm-ntgr
Sep 08, 2014NETGEAR Employee Retired
Unfortunately it looks like at least one of your disks is failing/dead
You should contact support. I would think a data recovery contract would be required in a situation like this before support could attempt to recover your data.
I see SMART errors on the disks.
