rhpot1991
Mar 01, 2012Guide
CyberPower CP1350PFCLCD
Readynas detects via USB, reads remaining time correctly. However it reports the battery charge incorrectly, always listing 12% even though the charge is at 100%. This seems to be an issue with NUT'...
Mar 12, 2013Guru - Experienced User
Auto-shutdown depends on a different message on the USB (power critical or something like that). So it might not affect it (though of course that might be wrong as well).
I have two CyberPower CP1350AVRLCD units, which work fine with my v1 duo and nv+, as well as my pro-6, and they appear to read the power status correctly.
