Daryn
Jul 10, 2009Aspirant
Cyberpower CP1500AVRLCD
The charge % and time remaining match that of the display on the UPS. The ReadyNas will properly shutdown too.
ChrisMc73
Aug 11, 2011Aspirant
claykin wrote:
ChrisMc73 wrote: How do you configure the ReadyNAS software to work with this UPS and my ReadyNAS to gracefully shut it down?
Do you have to do anything besides enable it in Frontview? I didn't know what to put in that blank box for other hosts...?
In Frontview go to the SYSTEM > POWER menu. Here you can set the threshold for the NAS to shutdown.
These settings will shutdown devices connected to the UPS. Not the UPS itself.
Ok, right now its set to AUTO, what does that mean? How does it automatically work? Should I change it to a certain time instead? What do you recommend?
What is the next thing under that for, the empty box for a host name?
