readynas12
Jul 29, 2019Aspirant
DATA FROM FAULTY NAS
My Ready NAS will not turn on, I am not a Guru so simple language please!, local PC shop cannot get the drives to show up connecting directly to a PC is this a common problem and or is there an e...
- Jul 30, 2019
The remote is when you put the drives in your new NAS. They remote into it and mount the volume so you can offload the files. But you have to store them on other media such as a USB drive (which gives you a good start on the backup you should have, anyway) so you can then factory default the new unit and put the files back on the NAS with it's new drive format.
Yes, if you have a way to connect all the drives to a Linux system, then you can mount the volume there..
readynas12
Jul 30, 2019Aspirant
Excellent, many thanks for your detailed, quick and to the point answer.
I doubt we will be able to do a remote as there is no connection to the unit, however do you mean we should be able to plug the dives in to a Linux machine with an adaptor to get the data?
Sandshark
Jul 30, 2019Sensei
- StephenBJul 31, 2019Guru - Experienced User
You'd boot up the NAS in "tech support mode". That allows Netgear to access it remotely. Support would give you more detailed instructions if you go down this path.
