weddlerr2
Jan 25, 2020Aspirant
Data inaccessible - kernel BUG at fs/inode.c:556!
Hello, I am having an issue with my data volume being inactive. I recently updated the firmware from 6.9.5 to 6.10.2. After the update, I found the data volume as inactive. A log error of "kernel...
weddlerr2
Jan 30, 2020Aspirant
I thank you and JohnCM_S for your kind help. I am currently using reclaime software to recover the last couple of months. The process is slow. Browsing through the files as it searches, it is amazing the amount of corruption that a single incident can cause. I have had several incidents where /data files have ended up in the system root and have filled it to it's 4gb limit. Up until this time, I have fixed it with little to no issues.
Jan 30, 2020Guru - Experienced User
After you recover the data, I suggest that you put a backup plan in place for your NAS. As you are finding out, data recovery is a lot of work, and often you can't recover everything you need.
