jvozgr
Aug 19, 2016Aspirant
Data recovery from inactive volume of ReadyNAS RN104 with four 4TB hard disks RAID-5
Hello, After replacing a disk on channel-2 with a new one and while resyncing at about 60% of the job I lost contact to my data. The message on the top of the screen is "Remove inactive volumes ...
Retired_Member
Aug 21, 2016Slightly more general question relating to this....
"Yes during the resync another disk in bay 4 encountered problems and changed to FAILED...."
Given the above, could someone please explain or provide a reference on how RAID5/6/10 on the RN's detect disk failure? Do these NAS boxes auto-detect failed disks prior to data use? I presume these boxes use hardware RAID controllers, but are software configurable?
It appears that the above disk failure(s) were detected only during a resync in the above case, and not pre-detected? Is S.M.A.R.T (for SMART drives ofc) enabled on RN's? for that matter, I thought S.M.A.R.T. was used for detecting failing disks? Or are regular RN disk maintance schedules required to detect failed disks (scrub/balance, etc.)?
- StephenBAug 21, 2016Guru - Experienced User
When the disk is inserted, a SMART self test is run. You can also schedule SMART disk tests as one of the maintenance functions.
The system does monitor SMART stats, and the drive firmware can the NAS that it has failed. Of course the disk driver can also discover that the drive is not responsive, and at some point will declare the drive to be dead.
The RN104 uses software RAID, but there is hardware acceleration
- mdgm-ntgrAug 21, 2016NETGEAR Employee Retired
I think the system does a short SMART test automatically daily and on boot with the option to schedule a longer test or run it from the boot menu.
SMART is useful in detecting problems with disks but it's not perfect. It won't detect every possible problem.
If you download your logs and look in smart_history.log you can see the history of key changes in SMART error counts.
Before replacing a failed disk it's important to check the stats to see how the other disks are going.
- Retired_MemberAug 21, 2016
unfortunately my smart_history.log only shows the S.M.A.R.T. info when the drives were first installed (1 for each initial drive)
How does one schedule for S.M.A.R.T. checks on OS 6.5.1?
