passion4melody
Jan 05, 2020Aspirant
Data Recovery ReadyNAS 102
I was curious if it is even possible to recover data from either drive after confirming the FACTORY reset and immediately pulling the plug 20seconds after i realized i had initialized the wrong Read...
Marc_V
Jan 06, 2020NETGEAR Employee Retired
Welcome to the Community!
It should not have any data loss since you powered down the NAS or unplugged the power after 20 seconds. There is a 10-minute timeout period for the Factory reset, if you powered down the NAS before the 10-minute mark ended the system powers down safely without causing any data loss.
However, it is a different scenario if you have pressed the backup button after putting it on Factory reset. This will start the reset immediately.
Were you able to try and boot your NAS normally?
HTH
Regards
passion4melody
Jan 06, 2020Aspirant
the data seems intact, but the NAS was completely reset. Doesn’t show data or file structure after reboot in the NAS. currently trying to view the disks, but having an issue because of the BTRFS file system. using a bootUSBdrive with Live. So far no real easy luck until i started a last chance signature file recovery. it’s a very slow progress, but it’s finding files.
