Chris_S
Mar 28, 2012Aspirant
Dead Disk.. but not really
Does anybody have the same problem? So far this has happened twice to me:
brand new Ultra6. I get the message that Disk1 (also brand new, no SMART errors etc) is dead (out of 4 disks with dual redundancy Xraid2). I put in a replacement disk, nothing happens. No re-synching, on the webinterface, Disk1 still shows up as dead. I put back the original disk1 and reboot, everything is fine again. This has happened twice. My question: apart from why does a good disk show up as dead when it isn't, isn't the unit supposed to integrate the new (replacement) disk on the fly?
I am wondering if something is wrong the my chassis. Because:
about a week after I bought the unit and after running it on 3 disks, I put in a 4th one and then it crashed while re-synching. The unit would then not go properly into tech-support mode, only after several OS-reinstalls (basically, when in tech support mode it picked up an IP address outside my network!?). Netgear tech support eventually managed to get some of my data back (they too could not figure out what had happened in the first palce and/or why my unit would not go into tech support mode), but that took several weeks. In the meantime I tried to return the unit but the shop would not take it back because it's past the 2 week return period..
Thanks a lot!
Thanks a lot!
martinsbootfair wrote: ...1: with Xraid 2 my understanding was I can start off with one drive and incrementally add others, up to the max of six. Auto volume expansion will just do it's job. How do you do this in reverse if you have a problem with a faulty drive? ie take the drive out and tell the volume to adjust itself to the new situation?
2 If that is not possible how do you test your new drives BEFORE putting them into the Raid with the same software that the Raid uses?
3: Should I take out a running drive and replace it with a different drive as a test maybe?...
1: the replacement method is in the PRO FAQ (http://www.readynas.com/?page_id=5073). You take out the old disk, wait for at least 10 seconds, and insert the new one. (It will take more than 10 seconds to put the new disk into the tray anyway...). What you can't do is downsize the volume. It would be nice for several reasons, but you can't.
2. My suggestion for that is to use vendor tools (which of course is not the same software that the NAS uses).
3. I wouldn't do that. The resync process stresses the remaining drives.
BTW, Seagate will take back your drives even if you don't use their test. (Apple users can't run Seatools at all). You use one of the error codes here: http://www.seagate.com/staticfiles/supp ... codes.html They do reserve the right to reject it if they decide the drive is good, and will charge you for return shipping. They have never done that to me, and I have sometimes used those codes. Seagate will give you a refurbished drive, and the model will not always match what you returned, and might not be on the HCL. So in general you are better off exchanging them through the retailer if you can (probably too late for you I realize). - Ignite141AspirantI'm having a similar problem with my ReadyNas Duo. Disk 1 Seagate ST31000333AS is reported as dead but is, in fact, working fine, i.e, I can find it on my network and access all files. I have recently replaced what I think was a truly dead Disk 2. My problem is that, because Disk 1 is deemed to dead, configuring Raid is not an option - Resync volume is greyed out and "Status: Not redundant. A disk failure will render this volume dead" is reported.
I have tried replacing Disk 1 with both the old and new Disk 2 but then I can't access the Nas on my network. Only when I put the supposedly dead Disk 1 back in the Nas can I access the files but I still can't configure Raid. As far as I can see, my new Disk 2 is sat doing nothing and all will be lost when Disk 1 really does die!
Can anyone help? - StephenBGuru - Experienced UserHave you reviewed the disk health on drive 1? Even if you can access it, it could possibly be sick.
Assuming it is truly healthy:
-Though it is brute-force and ugly, you can perhaps clone disk 1 to the new disk 2, and put that new disk into slot 1 and boot the Duo. If it works, you could then delete the partitions on the original disk 1, and insert it into slot 2.
-If you have a backup, you could also reset to factory defaults. (If you don't have a backup you should make one!). A variant here is to temporarily install the new drive into your PC and copy the data onto it. Then factory default drive 1, restore the data. Finally delete the PC partition on the new drive and hot-add it to the duo.
Or submit an on-line support case of course. If you are not feeling too anxious, that is probably the least work. - Ignite141AspirantStephen
Thanks for your reply. What's the best way to check the disk health on drive 1? There doesn't seem to be any utility on the Nas - everything to do with that disk is greyed out. - mdgm-ntgrNETGEAR Employee RetiredIf you download the logs (Status > Logs > Download all logs) do you see a disk_smart.log with health info for the drive?
- Ignite141AspirantI can't say that I understand all the log details but
===START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART Error Log Version: 1
No Errors Logged
WHEN_FAILED is blank for all attributes
Results are similar to those of disk 2, which is recorded as healthy and has a green light.
I can't see any evidence that there is a problem with the disk. - mdgm-ntgrNETGEAR Employee RetiredDo you see any ATA errors?
- Ignite141AspirantThe only reference I see to ATA is:
ATA Version is: 8
ATA Standard is: Not recognized. Minor revision code: 0x29
This is the same for disk 2.
Can't see any reference at ATA errors but not sure where to look! - Chris_SAspirantWell, the L3 engineer spent quite some time on my unit, the end result is that I will be getting a replacement chassis. He did mention that there might be some issues with that particular model of Seagate drives (despite being on the approved list).
- mnotAspirantFWIW - same problem for me; really annoying. Ultra 4 + Seagate ST2000DL003-9VT166, which is on the HCL.
