DWR5050
Nov 14, 2024Follower
Dead Power Supply...now no volume exist
I have a client with a ReadyNAS Pro that had some older data on it that is needed. Power supply died, so I swapped it out with a known good one. At bootup, web interface comes up but receiving "No ...
Nov 14, 2024Guru - Experienced User
DWR5050 wrote:
I have a client with a ReadyNAS Pro that had some older data on it that is needed. Power supply died, so I swapped it out with a known good one. At bootup, web interface comes up but receiving "No volume exists." Also with the error Remove inactive volumes to use the disk. Disk #1,2,3,4,5,6.
Running firmware 6.10.8
I can access the NAS via SSH. Hoping to bring volume back online to move data to new NAS.
Download the full log zip, and then look for the details in the log. It might just be that the array is out-of-sync due to cached writes being lost then the PSU failed. That usually isn't difficult to fix (though there might be some data loss).
But if there was a power surge when the PSU failed, if might have damaged one or more disks. That would be much more difficult.
If you need help examining the logs, you can send me a link via PM. Just make sure the link permissions allow anyone with the link to download.
DWR50
Nov 14, 2024Aspirant
Here is the logs via a dropbox link:
I could use your help deciphering the logs.
