Bowlinra
Jan 13, 2012Aspirant
Dead ReadyNas 1100?
Found my 1100 power off, and I don't get anything by physically turning it the On/Off switch. No lights. No Fan. Unit was attached to an UPS and was actively used the day prior. I guessing it's the po...
mdgm-ntgr
Jan 13, 2012NETGEAR Employee Retired
Provided your disks are fine your data should be recoverable.
Here is what I suggest:
1. When you get the replacement unit, put a spare disk (must not be from your array) in it (doing a factory default if necessary) and ensure it's running the latest firmware. If not running the latest firmware, update to that firmware, rebooting when prompted. Be sure to verify the update was successful.
2. Then power down, remove the spare disk and follow the migration procedure I linked to above.
Now when you attempt to boot the replacement 1100, monitor the NAS in RAIDar (http://www.readynas.com/downloads). If when you click setup you are prompted with a dialog window to choose RAID modes rather taken to Frontview power down immediately however you can.
