njd
Sep 21, 2012Aspirant
Dead ReadyNAS Duo v2?
I bought a ReadyNAS duo (v2, stock fw4.1.6) about two years ago. My first unit died on me on first setup. I remember trying all sorts of documented restore procedures with no luck and ended up receivi...
mdgm-ntgr
Sep 21, 2012NETGEAR Employee Retired
“Bad contents on root partition of disks” suggests a problem that would require remote access from support to fix. What did you do to try to recover the system?
You have a Duo v1 hardware revision 2. Do note that the Duo comes with a 3 year warranty.
