diverguy
Nov 05, 2012Aspirant
Dead ReadyNAS Ultra2, how to retrieve files?
Hi, I have a ReadyNAS Ultra 2 with two WD Green 3TB drives of which the LCC problem was solved by applying the WDIDLE3 tool early on. The other day I wanted to detach the MyBook 3TB that I use for ba...
vandermerwe
Nov 05, 2012Master
Unless you have access to another Ultra 2 chassis, I would contact support, particularly if the unit is still under warranty.
