diverguy
Nov 05, 2012Aspirant
Dead ReadyNAS Ultra2, how to retrieve files?
Hi, I have a ReadyNAS Ultra 2 with two WD Green 3TB drives of which the LCC problem was solved by applying the WDIDLE3 tool early on. The other day I wanted to detach the MyBook 3TB that I use for ba...
Nov 05, 2012Guru - Experienced User
Since your chassis fails to boot, then likely you will get an RMA. If your disks are ok, then you should be able to plug them in, and everything should be ok.
