diverguy
Nov 05, 2012Aspirant
Dead ReadyNAS Ultra2, how to retrieve files?
Hi, I have a ReadyNAS Ultra 2 with two WD Green 3TB drives of which the LCC problem was solved by applying the WDIDLE3 tool early on. The other day I wanted to detach the MyBook 3TB that I use for ba...
diverguy
I knew I could not escape explaining why my unit has no warranty anymore. :) That's because of the same reason I don't effectively use my Duo anymore: salt in the air here where I live. Everything with forced air cooling is problematic.
The pcb in the Duo shows signs of corrosion. Especially around the USB and Ethernet ports.
That's why I retired it and purchased the Ultra2. But before putting the Ultra2 into use I covered the pcbs with a sprayed polyurethane clear coat for electronics.
I don't think Netgear appreciates that. My unit was bought in March this year.....
