diverguy
Nov 05, 2012Aspirant
Dead ReadyNAS Ultra2, how to retrieve files?
Hi, I have a ReadyNAS Ultra 2 with two WD Green 3TB drives of which the LCC problem was solved by applying the WDIDLE3 tool early on. The other day I wanted to detach the MyBook 3TB that I use for ba...
mdgm-ntgr
Nov 05, 2012NETGEAR Employee Retired
Something like
You might need to install mdadm and/or the lvm stuff via apt-get if they are not already present on the Linux machine.
mdadm --assemble --scan
vgscan
vgchange -ay c
mount /dev/c/c /mnt
