diverguy
Nov 05, 2012Aspirant
Dead ReadyNAS Ultra2, how to retrieve files?
Hi, I have a ReadyNAS Ultra 2 with two WD Green 3TB drives of which the LCC problem was solved by applying the WDIDLE3 tool early on. The other day I wanted to detach the MyBook 3TB that I use for ba...
mdgm-ntgr
Nov 05, 2012NETGEAR Employee Retired
Yes. If you're running a different OS that has those tools there might be a different package manager used to download and install tools.
The ReadyNAS does run customised Debian Linux so the best machines to use to recover data from a ReadyNAS array would probably be Debian/Ubuntu machines.
