glamisman
Jan 13, 2015Aspirant
Degraded Volume? #24527711
I have a RN102 that has two 1 TB drives and they are closed to be full, so I bought 2 3TB drives and installed one in the second bay and it synced up fine, but it duplicated the same size drive, so th...
mdgm-ntgr
Jan 13, 2015NETGEAR Employee Retired
When you insert a second 3TB disk it should do a sync (this would take several hours) then after that completes your volume should expand.
