glamisman
Jan 13, 2015Aspirant
Degraded Volume? #24527711
I have a RN102 that has two 1 TB drives and they are closed to be full, so I bought 2 3TB drives and installed one in the second bay and it synced up fine, but it duplicated the same size drive, so th...
glamisman
Thanks, I will insert the second drive and hopefully it will sync fine and expand to 3Tb.
Thank You...
Thank You...
