armornone
Apr 04, 2013Aspirant
Difference between Readynas NV+ V1 and Readynas NV+ V2 ?
Hello. Do both the NV+ V1 and V2 models look identical ? Is there anyway to tell the difference between the NV+ V1 and V2 from physical appearance? I believe I have purchased an NV+ V2 however...
armornone
mdgm wrote: I have a beta Duo v2 unit and a production Duo v2 unit. They both have the rear layout of a Duo v2.
Sounds like your reseller is either still selling Duo v1 units or they haven't bothered to update the pictures they show to show the correct one the Duo v2.
Or possible copied and pasted the information about the V2 from the website and the 3TB drive inside the unit may have been a failed attempt to expand( since the V1 have a max HD of 2TB in size)
So bottom line is if it looks like a V1 then it must be a V1 ?
That is a shame. I was hoping to get something that could support the larger hard drives.
