armornone
Apr 04, 2013Aspirant
Difference between Readynas NV+ V1 and Readynas NV+ V2 ?
Hello. Do both the NV+ V1 and V2 models look identical ? Is there anyway to tell the difference between the NV+ V1 and V2 from physical appearance? I believe I have purchased an NV+ V2 however...
armornone
Apr 05, 2013Aspirant
mdgm wrote: You should seek more information from the reseller. Maybe a picture of the box it is in.
Unit is used and no box there. How else can I confirm this? Can I tell from getting the serial number or part number from the device? Is that printed anywhere on it?
Thanks.
