armornone
Apr 04, 2013Aspirant
Difference between Readynas NV+ V1 and Readynas NV+ V2 ?
Hello. Do both the NV+ V1 and V2 models look identical ? Is there anyway to tell the difference between the NV+ V1 and V2 from physical appearance? I believe I have purchased an NV+ V2 however...
armornone
Apr 05, 2013Aspirant
chirpa wrote: If the serial number starts with 000DA2, is it definitely a v1.
USB ports on the back of the v2 are blue (for USB3.0).
I have confirmed it does indeed start with 000DA2. So it look to be first generation.
