steveoelliott
Feb 18, 2013Luminary
Difference between RNDP6000-200EUS and RNDP6310-200
Hi, I've heard that the RNDP6000-200EUS is EOL and been replaced by RNDP6310-200. What's the difference? Is it still possible if using the newer model to swap the drives out of one and into the ...
mdgm-ntgr
Feb 18, 2013NETGEAR Employee Retired
One is diskless and the other comes with disks installed.
You can migrate from one Pro 6 to another. First ensure (if possible) that the firmware version is the same on both units then follow this procedure: http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
