steveoelliott
Feb 18, 2013Luminary
Difference between RNDP6000-200EUS and RNDP6310-200
Hi, I've heard that the RNDP6000-200EUS is EOL and been replaced by RNDP6310-200. What's the difference? Is it still possible if using the newer model to swap the drives out of one and into the ...
steveoelliott
OK Thanks.
I was aware that there are multiple versions of the Pro 6 so providing the migration of disks between units is reliant on FW being the same and not affected by minor HW differences then that's not a problem.
It appears that diskless units are not available now, hence why I am purchasing an older version.
