Campus
Oct 06, 2013Luminary
Disable oplocks on ReadyNAS-OS6
Hi, I am currently evaluating ReadyNAS-OS6 and I cannot find the right place to disable oplocks for samba sharing. Any idea how to disable oplocks? Thanks, Campus
Skywalker
Oct 15, 2013NETGEAR Expert
Yes, Samba 4. It still supports SMB1, so of course the configuration parameters will still be there. But modern clients will negotiate SMB2/3.
From http://support.microsoft.com/kb/296264 (and various other places):
We do plan to release a sort of "SMB extended controls" app, with which you can tweak more advanced settings, similar to editing the Windows registry. So when that is available (should be soon), you should be able to switch off SMB2/3 support and disable oplocks for SMB1.
You cannot turn off opportunistic locking for SMB2.
