Campus
Oct 06, 2013Luminary
Disable oplocks on ReadyNAS-OS6
Hi, I am currently evaluating ReadyNAS-OS6 and I cannot find the right place to disable oplocks for samba sharing. Any idea how to disable oplocks? Thanks, Campus
Campus
Oct 17, 2013Luminary
Ok, that sounds great. Thanks for the update. I don't really care about SMB2 as AFAIK the main benefit is speed which is less important than data integrity. Unfortunately I have to run a badly implemented database software which simply breaks stuff if oplocks are enabled.
