ChamITGuy's avatar
ChamITGuy
Follower
Nov 12, 2018
disable raid
I have a RN102 with (2) 1TB drives in a x-raid radi1 config.   What I want to do is:
- install a single 6tb drive
- clone data
- disable raid
can't figure it  out.   Suggestions?
1 Reply
  • Retired_Member's avatar
    Retired_Member
    Hi ChamITGuy, I would do it like this:
    1 - Backup your data
    2 - Remove both old 1TB drives from the nas
    3 - Prepare the new 6TB drive to not hold any partitions. Could do that with a windows pc. If the disk is already blank, skip step 3.
    4 - Insert the blank 6TB drive into the nas. As it is a single drive, there will be no raid.
    5 - Restore the data from your backup to the nas
    Kind regards
ProSupport for Business
