funglenn
Jan 25, 2017Luminary
Disabled Readynas Network interface
Help. I accidentlaly disabled the network interface eth0 and now i cannot get the icons back to renable it? what do i do? i only temporarily wanted to disable to troubleshoot something. it literall...
- Jan 25, 2017
No it doesn't affect apps
bedlam1
Jan 25, 2017Prodigy
Which ReadyNAS model ?
- bedlam1Jan 25, 2017Prodigy
From other posts by you I see it is a 516
Have you tried plugging your ethernet cable into the other NIC (eth1) or connecting directly with PC to eth1
Failing that you need to perform a Boot Menu OS Re-install (NOT FACTORY DEFAULT) following which your password will revert back to the default of "password"
it will also enable DHCP so an IP address will be allocated to your 516
